BX24 overflow tank boiling 🔥
skatingtoolman
Kubota BX24 & M5660
May 20, 2024
Nelson County Virginia
I have reviewed other's posts on overheating, but this has me stumped.
I am losing coolant, but there are no apparent leaks.
  • I ran an oil detection test in the radiator to test for possible cylinder or block cracks. Tested ok and no apparent milkyness (sic) in the oil.
  • I removed the thermostat, first noticing there was zero water in the block, probably due to the radiator being almost empty. I am now running it without a thermostat. Still overheating.
  • With the overflow tank boiling, maybe the coolant is boiling and exiting via the overflow tube.
  • I am going to do a radiator flush next.
Why is it getting so dang hot? I've cleaned all of the usual suspect areas thoroughly, even removing the battery to do so.
Any suggestions would be appreciated. I don't have the $$ to just rabbit out parts.
4,816
defective water pump. Most likely the impeller has come loose on the shaft and it isn't turning.
jaxs
B1750HST
Jun 22, 2023
734
522
If you "don't have $$ to rabbit out parts" you better not keep running it until you can beg,borrow or steal enough $$ to find the problem. Diesels are intolerant of overheating plus they reach higher temperatures than gas engines quickly resulting in catastrophic failures.
Dusty's suggestion of loose impeller is plausible and fairly straightforward to check. Radiator can look clean but still have lots of trash between fins blocking airflow. Fans commonly have a shroud surrounding them and if missing or improperly installed causing lack of airflow.
2,551
I'm with Dusty - check the belt on the pump and the pump !
JeremyBX2200
BX2200
Aug 3, 2020
466
436
Indiana
Following this thread. I have a similar issue with my BX2200 when mowing. I know mowing can cause more heat.
jaxs
B1750HST
Jun 22, 2023
734
522
If it never runs hot on other chores your tractor likely runs hotter while mowing because it is being run in too high of gear and/or too low rpms.
The price of live data reader will be returned several times over through prevention of engine damage and extended life. When live data reader shows temperature going up you can take some load off engine until temp drops back to normal. When live data on my trucks show temperature going up downshift to lower gear with increased rpms always brings temp right back down. Any experienced semi mechanic will tell you more diesels are killed by running hot than everything else combined. It requires an experienced ear to detect when diesel begins to labor. Cruise control has allowed trucking companies to show drivers how to hold the wheel and let computer handle throttle and gears. Were it not for killing new tractor sales and dealer repairs compact tractors would have computer controlled drive trains.
4,900
flush the rad before you remove the water pump !
You don't say how old or hours on the machine
but rads need to be clean INSIDE as well as out. Pop the hose off and 'backflush ' with garden hose for a good 10 minutes.
reconnect, fill with warm water, run engine and test.
generally rads fail before pumps.
JeremyBX2200
BX2200
Aug 3, 2020
466
436
Indiana
I am using a new to me 3pt finish mower this year, so still figuring out best way to mow with it and my BX2200.
I really haven't done anything to the tractor cooling wise the last 3-4 years except making sure the coolant level was good and looked clean because it always ran in the normal range.
A few things I am gonna do before digging any deeper.
1. I purchased a longer air wand for my compressor. Gonna blow out the radiator and air screen to make sure it has optimal air flow.
2. Coolant looks clean, but it also looks like straight coolant. Gonna drain some and add distilled water to transfer heat more efficiently. I have used products like Water Wetter in my track cars before to help with heat transfer.
3. Probably replace the radiator cap since it is cheap/easy. Make sure it is pressurizing the way it should.
If these don't change anything then I will look at the thermostat and water pump. I will probably inspect the water pump belt too.
2,965
I use a vacuum cleaner from the operators side to suck the stuff that somehow finds its way to the radiator. If you do use air to blow the radiator out, you might want to blow from the engine side, opposite to the way air normally flows through the radiator…
You probably already thought about this…
JeremyBX2200
BX2200
Aug 3, 2020
466
436
Indiana
Thanks for the pointers
JeremyBX2200
BX2200
Aug 3, 2020
466
436
Indiana
I used my extendable air wand to blow out the radiator and cleaned the screen. Mowed once since then and the tractor stayed at normal operating temperature.
The outside temperature was lower than it had been before, so I won’t know for sure until the summer temperatures set in.
