I built a thumb for my bx24. I just wanted something light duty, mainly to pull up small saplings and pick up piles of limbs, etc. and take them to the burn pile. (save a little work on my old back). I did take it out back and picked up a log approx 600 lbs, the thumb didn't brake off. I guess that's a good thing.
The piece I welded onto the boom is a piece of seamless reciever tube 5" long.
the 'stinger' is 1/4 wall 2" square tubing 16" long. The diagonal brace is 3/8 x 2
flat bar. The piece with the teeth is 5" channel 5" long. I drilled a series of 1/2" holes then cut through the center of the holes to make the teeth. When I pull the pin, the only thing on the boom is the reciever tube. As you can see in the pics, I didn't weld across the boom. I think it will serve my purpose.
The paint is Rustoleum Lobster Red. Pretty good match.
