BX23s throttle snapped... might have an improvement idea
Rustyclockwork
BX25D-1 (stolen) now have BX23S
Nov 8, 2014
Lebanon, Indiana
My throttle control lever snapped at around 200 hrs. I'm going to order another one, but going to do a small improvement... Under the plastic dash, I'm going to mount a bonze bushing in a housing that the new lever will pass through and hopefully this will lessen the leverage stress that the stock system has to deal with.
Hope everyone is having a good day,
Jason
Rustyclockwork
Nov 8, 2014
Lebanon, Indiana
I created my account when I got the BX25D-1, that tractor was stolen a few years after we got it. Kubota insurance replaced it with the first year version of the BX23S (I think it was the first year). I should update my profile!
Jason
Is this a BX23S or a BX23D-1? The title and your member information differ.
gh0stee
BX23S
Oct 14, 2025
I have this same issue, it's looking like I gave to take the steering wheel off. Did you have to?
Bearcatrp
Mar 28, 2023
1,037
657
Minnesota
mine happened a little over 200 hour. You will need to remove the steering wheel and dash. Not hard. The 2 nuts are the adjustmen. Put 1st one on tight, test. If it’s too tight to move the lever, back it off a little. Once you find the right tension, put other nut on tight against the 1st nut. Mine is just right tension now. Good luck.
Grampus
Kubota BX23S
Oct 7, 2025
TN
Jason
I've had a BX-23S for about one year. When I bought it (50 hours) the throttle lever was extremely stiff. One of the first things I did was to loosen the nuts under the dash until the Lever turned more easily. Haven't had a problem since. Before I went to the effort of adding a bushing, I would try loosening/adjusting the nuts. I think that will solve the problem. BTW, you shouldn't have to remove anything to access the nuts. I didn't. Good luck.
CORRECTION- you will have to remove the battery cover panel, but that's a routine maintenance item.
Bearcatrp
Mar 28, 2023
1,037
657
Minnesota
Removing the dash is only needed to replace the lever. Mine was super stiff when I bought it. Thought that was normal.
