BX23S Starter engaging while running
Lug66
LX2610HSDC, Z422KWT
Jun 7, 2023
121
67
SW Michigan
Hopefully parts chucking solves the problem. In case it doesn’t:
Have you inspected the wiring? A chaffed, always hot, wire contacting a chaffed intermittent hot, attached to a relay or switch, can cause voltage to pass to a circuit that should be cold. Don’t rule out a shorted relay socked. These could also be temperature sensitive.
The only other thing I could think of is that something crazy is going inside your starter solenoid like a broken bus bar or spring.
whitetiger
Nov 20, 2011
3,636
2,060
Kansas City, KS
I swapped all the relays around. I just bought 4 new ones, and will replace them all when I put the new starter in later in the week.
Its been randomly engaging the starter while the tractor runs, but only for a second. When this happened before the tractor started itself several different times. I would wake up to the sound of it running outside. That stopped after replacing the ignition switch, but i obviously still have issues going on.
Is your serial number below #45946?
If yours is above, there are 5 relays.
3,393
From post 31 above:
I unplugged the black/white wire and the starter stopped. So I put a disconnect switch on the black/white wire. ON for start and then switch to OFF after starting. I used the tractor all day and the starter never kicked in one time during use with the switch in the OFF position...
Rather than destroy another starter might be advisable for you do the same thing as RK (post 31) did. And then after that apply logical troubleshooting procedures as others have expressed above.
kgrose
BX23
May 9, 2026
WA
From post 31 above:
All of the issues 100% resolved after I replaced the ignition switch and starter 6 months ago. After about 100 hours of run time, while running the tractor all of this happened again. Had i been having intermittent issues after replacing these components prior, then I would have starting troubleshooting shooting further. I thought it was resolved with the ignition switch. When the other day the starter engaged, and shutdown didn't work, and the tractor didn't shut down until the starter blew up, I started this process. I thought I was being logical in replacing the switch and starter and everything ran properly for 100 hours. Now that it happened again out of the blue, I know that there is another issue at play. I will be investing as stated above. All of the suggestions posted have been helpful and I appreciate everyone's insights.
3,393
I think you are the third person in this thread expressing the same issue, so it does get a bit confusing remembering who's who.
But since you are not RK of post 31, I still would suggest you try what he did as an interim step while searching for the root issue.
