BX23s issues with oem wheel spacers 1.3"
NorthernEric
BX23s
Sep 7, 2026
ON
New 2026 BX23s, I bought wheel spacers form the Kubota dealer, bx8613, go home and the 1.3" oem spacers don't fit the rear axle inner wheel hub center lip. Somehow in 2026 Kubota change the rear inner wheel hub center lip which is bigger. Has anyone found any wheel spacers that will fit the 2026 model. Dealer asked kubota on ETA for factory wheel spacers and came back with no answer as to when.
NorthernEric
BX23s
Sep 7, 2026
ON
I was back at the Kubota dealer today, returning the wheel spacers, parts guy can't find any other spacer that will fit, Kubota still has no ETA on a new fabricated part. So the inner wheel hub ring is 3", look like they went to wheel hub centric?
Spam Bot
Windows Computer
Aug 3, 2024
190
134
Austin, Minnesota/Key West FL
I purchased wheel spacers designed for a Jeep with the same bolt circle as the rear wheels on my 2020 BX23S. I believe that I paid about $60 for the pair. The center hole was much larger than the Kubota hub; however, the lug nuts keep it properly centered, and I have had no issues with it for over 5 years. If you purchase them on Amazon and they don't fit, you can get a full refund from Amazon, and you can drop off the "defective" product at any Staples store. Once you drop it off, you get a full refund to your account the same day.
BX23-S,57 A-C D-14,
6,318
If they went 'wheel hub centric, then would they also have to change the rims and nuts ?
