I pulled the glow plugs, and they look fine. I'm not sure if there is a relay or controller someplace on the tractor. I can't find it. Any suggestions?
The 'glow relay' is controlled by the ign switch. The dash light and glow plugs are fed from from that relay (light has it's own 5 amp fuse.
Sadly the WSM doesn't have a picture of the fuse panel or WHERE the GP relay is....
I'll look behind the dash grille ( where battery/fuse are located) tomorrow
Ok I did find the 5amp fuse and its fine. I guess I need to start to unwrap the wiring and follow wires. I thought there might be a relay that was easy to find. Maybe the ignition is where I need to start. Thanks
