BX2360 Oil leak
Ulijohna
BX2360
Jun 30, 2021
Indiana
Hello Kubota friends!
I have a Kubota BX 2360 that has developed a leak from the rear engine crank seal. ( nearest the back of the tractor ). Does the engine require removal to replace this seal, or is there another method of removal? Scratching my head!
Thanks, Ulijohna
whitetiger
Nov 20, 2011
2,735
1,240
Kansas City, KS
Thanks, Ulijohna
The seal you are referring to is the Front crankshaft seal. What dictates the "front" of the engine does not refer to how it is mounted.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,131
129
Hardisty, Alberta
The easiest way is to lift out the engine. It is not a bad job to do at all if you have a lifting device.
eserv
May 27, 2009
2,131
129
Hardisty, Alberta
I lift the rad out with the engine. I find it easier than fighting with the fan and shroud
