BX2360 Cab on BX25D ?
BMDBX25
BX25D TLB
May 5, 2014
NL Canada
Hi guys I'm new to the forum, and I don't know much about the BX2360 but i was offered a great deal on a cab but I can't find information on whether or not it will fit my BX25D. Any help would be greatly appreciated.
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
The BX2360 has no backhoe so that may make it incompatible with your BX25D unless the cab is removed to operate the backhoe on your BX25D. Unless the cab has a removeable rear panel.
Sent from my SM-N920V using Tapatalk
2,221
there was a lot of differences between the 2360 series and the 2370 series......most in the cosmetic department, a few changes to the hoe, a few to the dash - but the big question is whether the footprint of a cab is the same. I would think it would be - but that is just a SWAG. IF you could measure points on a 2360 series (I am sure someone here has one) then you could compare point to point. Someone can chime in and give you that info!
1970cs
1,124
Grand Ledge
ROPS is wider and taller on the 25 to swing the seat and for head clearance.
Most of the cab units clamp to the ROPS uprights for extra support.
OP did not mention if it's hard cab or soft. Soft units can roll up the back window vinyl.
Pat
BMDBX25
BX25D TLB
May 5, 2014
NL Canada
Thanks for the feedback guys, after i dug a little deeper I realize that the ROPS would be the issue, because it is wider and taller. The footprint of the floorboard is similar but ultimately it would need modifying near the ROPS. It is a steel cab by the way.
Thanks again.
