BX23 head assembly marks or exact same cracks?
tshep
BX23
Feb 9, 2010
19
Richmond, VA
Hey - got these 3 combustion areas
They seem to be same size and exactly same place, with stake marks?
Cracks or not?
FRecommend home crack test system?
I hope I'm changing head gasket for tiniest of radiator bubbles.
Any help?
2,839
They look like registration marks,
explain: " I hope I'm changing head gasket for tiniest of radiator bubbles. "
8,908
Nope not cracks.
Someone scratched those in.
Use an OEM gasket!
tshep
BX23
Feb 9, 2010
19
Richmond, VA
I was expressing hope, that my only problem was the head gasket, to explain/fix tiny bubbles.
Based on reading, and my machinist's remarks, I may have the rare 'caught it before it cracked'!
8,908
I would replace the thermostat and the water pump, because both can cause bubbles too.
whatsupdoc
L3302
Jul 9, 2024
111
122
I would do a block combustion leak test, that way you can confirm if
there is combustion gas leaking into the coolant system.
Real easy to do.
tshep
BX23
Feb 9, 2010
19
Richmond, VA
So, machinist confirmed no cracks (!!), had OEM gaskets before I started.
Doc, you teasing me? How to 'block combustion leak test'?
tshep
BX23
Feb 9, 2010
19
Richmond, VA
OK, I get it... maybe I should have BEFORE I pulled the head?
NTL, if I see any bubbles, I will follow up!
