On my bx22d the rear lines that go to the backhoe there two ports but the bt601 attchment Im putting has three lines what I am getting at is I guess I have to install a return to tank/trans. line on the tractor valve body but not sure if there is a port plug or something available so i may have to tee into already dedicated return to tank line not sure what port/line/plug to use to acomplish this anyone done this I guess the bt600 that is supposed to be used only uses 2 lines no tank drain line I wonder why they went from 2 to 3
