Bx22D rear port lines for back hoe
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
Denver North Carolina
On my bx22d the rear lines that go to the backhoe there two ports but the bt601 attchment Im putting has three lines what I am getting at is I guess I have to install a return to tank/trans. line on the tractor valve body but not sure if there is a port plug or something available so i may have to tee into already dedicated return to tank line not sure what port/line/plug to use to acomplish this anyone done this I guess the bt600 that is supposed to be used only uses 2 lines no tank drain line I wonder why they went from 2 to 3
7,262
The two backhoe ports on the tractor are pressure out (P) and pressure return (PB) .
The third tank return on the BT601 backhoe can go to any tank access point. The oil filler jumps to mind but there may be other more convenient places.
Kubota has always cheated by using a cheaper two port BH valve with pressure IN and tank return (OUT) ports. That works as long as you never back pressure the tank port but its been a frequent cause of problems. They decided to do it "by the book" with the BT601 which has a 3 port valve with pressure IN (P), pressure OUT (PB), and tank return (T) ports.
5,365
Just for reference, my BH77 only has 2 hyd. connections.
Is this a “new to you” BH that you are installing?
If so, I think you would benefit greatly from a manual, or some sort of installation guide.
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
Thanks for the info just need to find where to port it back to tank
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
yes the hoe is new to me it attaches fine just thta extra line. I looked for a manual just for the back hoe but havnt found but a couple pages on it mixed in withe tractors it actualy goes on. OldHokie is right just need to find the port to plumb back to tank
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
Could well be BSPP.
There is a plug on the right side above the axle that plug sits just higher than the dip stick on the back so I am going to use that for my return to tank line. I pulled plug and it will work great Ill let you know how it works out when I get it plumbed up.
7,262
Looks good assuming it goes into the sump.. Almost certainly BSPP with sealing washer.
