BX2230 won't start
shybuck
Oct 21, 2020
38
10
eastern PA
Right in the middle of moving logs in the hot sun when the tractor won't start. Yes, it's in neutral but that's about all I would know to check besides the switch under the seat. Sometimes during a ride the engine would sputter like I was getting off the seat but then continue running like nothing was wrong. Could anyone offer suggestions on what to check in the engine? I'd really need to finish my work but I'd like to thank all suggestions !
10,658
PTO levers and HST pedal position are others that will cause no start.
And when you say no start...
Are you saying it's not even cranking?
Or are you saying it's cranking but not firing?
shybuck
Oct 21, 2020
38
10
eastern PA
I should have said, when I turn key there is NO response, no clicking, no instruments...as far as I can tell all safety switches are ok
10,658
OK now that sounds like a battery connection issue.
Check both sides of both cables.
Remove clean and reinstall.
shybuck
Oct 21, 2020
38
10
eastern PA
So here's what has happened. I looked at the fuses, then at the (key switch? directly behind key switch on dash)) and wiggled it as I turned the key and it started. So it will be running for the remainder of day, I'll replace ignition switch.
