Bx2230 lights
Tink
Bx2230
Aug 29, 2020
the lights on my bx2230 are on All the time. Can I turn them off, or do I need to remove the bulbs, or ???
BigG
Sep 14, 2018
1,951
770
West Central,FL
What if you pull the fuse to the headlights? What else is on the same circuit?
And the silly question what harm are they doing being turned on?
imnukensc
BX2380
Sep 10, 2015
687
590
Midlands of SC
Turn'em off with the switch. If that doesn't work then the switch may have a short and you can either take it apart and try to do a refurb on it or replace it.
Tink
Bx2230
Aug 29, 2020
Are they a Kubota safety issue that they need to be on including the taillights or if they should be off unless switched on, then I have a switch issue! If a switch issue I will either work on the switches or pull the fuses.
i just like to work without drawing attention from noisy neighbors! Thanks
Tink
Bx2230
Aug 29, 2020
If not a lights on safety issue than I’ll pull the fuse or work on the switches. Thanks
Tink
Bx2230
Aug 29, 2020
To all that responded, thanks, the problem is the switches are NOT weather resisterant. A shot of wd40 into the side hole made the switches work.
