Bx2200d mows fine for 10 min then dies? Help
billback
bx 2200
Dec 9, 2011
mt pleasant ,pa
Bx2200d mows fine for 10 min then dies? Help, i have replaced the fuel supply pump and fuel filters, also tested fuel cap vent by removing fuel cap when it has no power?
wv bc owner
100
US
Check your old filters for a slime like substance. Mine did the same thing last summer it was an algae in my fuel. If it is treat it with a algacide and it should fix the problem.
Sent from my HTC One using Tapatalk
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
15
Northern California
There is always the possibility that gasoline got added to the fuel tank. Similar symptoms.
Sniff the fuel to see if there is a gasoline odor.
2,280
Check all mentioned - but check IN THE tank too..... certain BX's have had the fuel gauge sending unit break apart and clog up the works as it floats around in the tank!
