bx2200d hydraulics
diesel4x4
bx2200d
Aug 10, 2019
Jessup
hello i have a bx2200d tractor .i want to put a power angle plow on it or possibly a front end loader .it is not equipped with a hydraulic system . what do i need ? where do i tap in the system or am i going to go broke doing this .thanks dave
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
195
162
Westford, Massachusetts
shelkol.com
The hydraulics get connected via a block bolted to the hydrostatic behind the left rear wheel. Get a parts diagram for a LA211 loader, the Hydraulic Block page item 140
4,872
With the price of Kubota parts, you are going to go broke if you need to purchase all the parts new. I would be looking for a BX1800 or BX2200 tractor that is being parted out, and purchase everything from that tractor to install on your tractor. The best part is if you can remove the parts yourself, because that way, you will know exactly where and how everything goes back together, and you will have every nut, bolt, washer, etc.. You might even want to look for a machine locally that has everything that you want, at a reasonable price.
5,426
I'm following Dusty's logic exactly.
To retrofit a loader on an older BX is going to be big bucks, even if you can do some/all yourself.
A plow will require the front hitch. They can be found, sometimes with the plow, but you need the correct model for the tractor. You still need to get the hydraulics to it.....
I would be apt to look at another BX equipped the way you want.
