BX2200 stuck in 4WD
Brycheiniog
BX2200
Aug 18, 2015
Cambridge, UK
Hi All,
At some point over the past couple of weeks my BX2200 seems to have got stuck in 4WD. The front drive control lever moves positively into each position but the front wheels are still being driven.
Any suggestions?
Jonathan
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Try reversing in a zigzag fashion on soft ground while selecting 2WD. Check the lever is connecting, and rotating the shaft the same amount as the lever is moving, i.e. check the roll pin isn't broken.
Stranger things have happened, you are definitely using the 2/4 select lever, and not the Hi/Lo or PTO engage lever by chance?
2,582
Hi All,
Any suggestions?
Jonathan
If the lever is moving in it's full motion, first check the linkage - possible something came loose, and the lever is just moving without doing anything else. Most of the time, if it stuck, the lever is very hard to move and rocking as was suggested will usually free it up. I hope yours is a simple "pin" or nut has come loose in the linkage.:)
