I just replaced both steering hoses, now it turns HARD. I can't seem to bleed the air out of the lines.. Any suggestions?
Did you try jacking the front wheels off of the ground and then trying to turn the wheels? With no ground resistance the wheels should turn easily even without any hydraulic help. If it still turns hard then you are fighting something.no, it labors as soon as you turn the steering wheel. Turning the handle all the way one way... then letting it set has improved the situation maybe 5-10% but it takes almost 30 seconds to turn the wheels from stop to stop.
