BX2200 , operational speeds
brian kivett
bx2200 with bucket, belly mower and scrape blade
Aug 17, 2026
fleetwood nc
does anyone drive theirs in high speed when using implements? not referenceing engine speed, but trans speed. also, getting prepped for snow in nc mountains, any usefull tips are greatly appreciated thansk
(Mod Edit: No emails on open forum, people answer questions here they don't email you answers)
11,077
Typically no work in high range, mostly used for moving tractor from location to location.
Useful tips:
Dress warm
Don't slide off a ditch, creek, river, cliff, mountain.
Don't start clearing a neighbors place for free... forget even free, just don't do it.
Shawn T. W
Dec 9, 2024
804
1,442
SW Missouri Ozarks
I use high range on a two range tractor that size pretty much only to move from one area to the next ... The little tires are quite rough riding though ... On my bigger tractor I've only used high range out of three (L,M,H) on my driveway to see how fast it would go ... But mow in M, Low is only used by me in very tight quarter maneuvering in the barn.
Grandad4
Apr 5, 2016
438
188
Greensboro, NC
High range is OK if you are mowing on some flat, generally level ground and the clippings aren't too thick. And, believe it or not, I used to mount and use a standard size PTO driven fertilizer spreader on my little BX occasionally, which required a higher ground speed. Did great except for the occasional lime pellet going down your shirt. Otherwise, high range is what they used to call a "road gear"
