BX2200 loader control replacement
bvtc
Bx2200 & L3301
Sep 8, 2026
Vermont
Ive got a bx2200 and need to operate a bx2750D snowblower on the front, but my tractor does not have a FEL or any of the FEL hydraulics, joystick, etc. Is there an aftermarket kit that will allow me to control the lift (up) and drop (down) of my snowblower? Thanks 1000031934.jpg
11,174
You can fit a simple spool valve to it to make it work.
Open center with power beyond.
At minimum you need the block to tap into the tractors hydraulic system.
Getting the whole kit would be the easiest!
11,174
You need all of these parts (and then hoses to the valve) to make the block work.
You can get the hydraulic fittings from other sources for much cheaper and you can match your hoses.
bvtc
Bx2200 & L3301
Sep 8, 2026
Vermont
So you think if I bought the valve box and then an aftermarket joystick kit I c
Please excuse my stupidity.... but you're saying that I'd need all the parts listed on Messicks site at the following link, and then I could purchase an aftermarket joystick, hoses and valve control to come off the valve box, correct?
11,174
In order to connect the block to the tractor you will need:
2 O-rings 75538-68130
2 Bolts 01053-50840
2 Washers 04512-50080
I looked up the fittings and they are not stupid priced so:
They are JIC so your hoses need to be JIC:
1 90 O-ring fitting to JIC 75595-64202
2: 45 degree fitting to JIC 75538-68153
Grandad4
Apr 5, 2016
443
192
Greensboro, NC
Off topic, but that's a very good looking first edition BX you have. Nice to see!
