BX1870 Won't Start
6,318
I did a search on here for "Safety Switch Test" and found this.
Definitely not your tractor, but gives you an idea, I hope.
http://www.orangetractortalks.com/forums/showthread.php?t=28812&highlight=safety+switch+test
Key switch could be an issue. Sounds like you do have a meter? All is checkable along the start circuit with your meter.
And you do have the WSM - - I think there is a decent electrical diagram if memory serves.
The screwdriver thing with the starter is just bridging the connections to it/solenoid to see if it will spin. You do not need to pull the starter to do it. Last time I did it was a '67 Chevy. Since I haven't done it in many years - I'm not qualified to coach that - it's also pretty tight down there.
sgraber
20
US
Thanks for the help everyone! After a lot of digging, it turned out to be a loose starter wire. Somehow it worked itself just loose enough that it was no longer making contact.
Edit: I took some pictures of how I blocked my bucket in the "up" position so I could tow it to the garage to work on it:
https://goo.gl/photos/bkS667P2468BAjyr5
6,318
Super - glad to hear - thanks for letting us know how you made out!!
So often, we never hear how things were, or weren't fixed.
Takes a lot of work to find a gremlin problem like that, but the good news is you found it!:D
Good for you!
