Out of the blue, my little orange critter started leaking tranny oil. It looked like the leak was coming from the oil seal for the front propeller shaft right at the tranny spline stub. I removed the HST filter and in examining it, I thought I detected a super tiny pin hole. I was super pleased that maybe - just maybe - the leak would/could be fixed with just a new filter. Fingers crossed.
So, i removed both u-joints and the front drive shaft. I put the drive in neutral and the FWD shaft spins just fine. Took a break for a parts run.
I will install a new filter, and refill the tranny, and then start it up. And i soooooooo hope the new filter did the trick.
Should that not be the fix - I'm not sure on how to remove the oil seal on the 4WD shaft after I remove the remaining parts and pieces to get to it. I do have a full set of 4 heavy duty "picks".... and is that what I use to pull the seal? (FWIW - I bought the "picks" when I replaced the seals in the bucket cylinder.) I'm assuming the 90° pick would work best...but again....I have no experience in pulling a seal that is actually on a shaft.
Any guidance would be most appreciated.
