BX1800 4x4 info
eagleback
BX1800
Jun 14, 2018
Sault, Michigan
Hello.
I just found this site looking for information about a bx1800 4x4. I do not know the year im thinking late 1990's early 2000's, it was my fathers. God rest, I do not have access to the tractor right now because i live in Florida and the tractor is in Michigan. The tractor has the usual attachments, Mower, blower, front blade, hard cab, The question i have is i want to add a front end loader, back blade and if possible a back how if it will fit especially with the cab. any info on this would be appreciated. and thank you in advance.
5,346
Re: New Member
The BX1800 was a very short run 2001-2003
Adding the front end loader is going to be very pricey around 3k minimum, unless you could find a used one (very hard to do) with all the right parts.
Back blade is just a pin on three point so that's easy.
A Backhoe if out of the question for that model.
5,346
Re: New Member
Maybe, just matters who made the cab and if it was designed for use with a loader.
I'm pretty sure it is not a stock option on that tractor.
