Hi guys. New to this forum.
I have a 2004 BX1500 that won't start. Below are the items that I have already done, and my tractor will not start. I appreciate any help you can give me. Thanks.
- Replaced starter solenoid with new solenoid.
- Was able to jump the starter to start tractor.
- Replaced with new ignition switch/key.
- Replaced ignition relay with new.
- Replaced all 4 safety switches and PTO front/rear switch (I thought it was a safety switch).
- Cleaned all electrical connections (safety switches, fuses, connections under hood) with electric contact spray, blown out with compressed air and reconnected with dielectric grease.
- Load tested battery – Good.
- Checked all grounds, cleaned with wire brush, and reconnected.
- Check continuity of wires.
