4x100 60mm bore. Still looking.Spacers really aren't recommended for the fronts but it's your tractor. I'm not sure where you would even find them for the front on a BX.
Yes i saw the pivot point argument, however physics dictates otherwise imo. Broken axle is concern but on larger tractors carrying large loads imo. the 1500 is overbuilt for its capacities. Fel is rated for like 400lb. Just ballasted front tires thinking to go foam fill instead and widen stance maybe ballast box on 3 point. Any idea on front spacers, source?Spacers are available for the front of a BX. But there is alot of debate whether to use or not. To each their own.
Still lookingHave you tried golf cart or atv sources, I can't remember exactly what I put on my golf cart but that 4x100 sounds very familiar.
Amazon has them... 1.5" Thick 4x4" 1/2x20 EZ GO Club Car Golf Cart Wheel SpacersNot yet. Atv looks promising.
Still looking
Yes i saw that. Pricing on site is confusing. It says price for pair like $140 but then when you check out the cartdoubles price. Im still looking around. Dont want to spend $500 for spacers if there is a alternative.I posted a direct link yesterday to BroTek. Got what you need.
Did you look at the information that I posted? This isn't rocket science, all you have to do is learn how to search. Search for Golf Cart Wheel Spacers. It is the same size wheel stud pattern.Its not a budget thing. I can make them. Its a my time vrs dollar thing. Haaaa ill call brotech tue. Thanks
You still have to match center bore on my fro its 4x100 60mm bore. Trying to find 3" for rear in the jeep fitment but bore size becomes an issue.Did you look at the information that I posted? This isn't rocket science, all you have to do is learn how to search. Search for Golf Cart Wheel Spacers. It is the same size wheel stud pattern.
The Kubota axle doesn't have a centering hole, so I can't see why you feel that you need one for the spacers. Sure, it would be nice and easy to install a wheel, but it really isn't necessary. If it is an issue, you could have a machinist cut you a collar that will be a interference fit over the locater hole in the Jeep wheel, and have a diameter a couple thousands smaller than the hole in the Kubota wheel, and that will accomplish what you are attempting to do.You still have to match center bore on my fro its 4x100 60mm bore. Trying to find 3" for rear in the jeep fitment but bore size becomes an issue.
Analyze the system again and show how wheel spacers on the front of a tractor with a center pivot can make a significant difference BEFORE an axle travel limit stop is reached. By that time it may be too late.Yes i saw the pivot point argument, however physics dictates otherwise imo. Broken axle is concern but on larger tractors carrying large loads imo. the 1500 is overbuilt for its capacities. Fel is rated for like 400lb. Just ballasted front tires thinking to go foam fill instead and widen stance maybe ballast box on 3 point. Any idea on front spacers, source?
