bx1500 stalls when put into gear, $25 reward for solution
joesmith123
L295DT, BX1500
Mar 18, 2023
527
134
earth
read another thread saying: bx1500 safety feature shuts engine off when seat sensor not satisfied
If you get the solution and i read your answer and it works, i send you $25
send cashapp/venmo with answer
joesmith123
L295DT, BX1500
Mar 18, 2023
527
134
earth
Ok now i jumped seat wires, bx1500 stays on when put into gear
Goes into gear, does nothing
I hit the throttle forward/back, nothing
I can operate the front bucket perfectly, just the wheels wont spin
What could it be?
6,366
Does the PTO spin?
6,366
PTO = Power Take Off = splined shaft out the back of the tractor.
joesmith123
L295DT, BX1500
Mar 18, 2023
527
134
earth
parking brake on ? or seized on ?
I tried hitting forward with this (pictured) up or down, it still doesn’t move
it could be seized, I’m thinking pull on with pickup truck to try to unseize
Or someone could tell me how to check if wheels are seized, I can lift it up
6,366
If it was seized it would drag the engine down.
The HST is not making any noise when you try and move it.
It acts like the range lever is in neutral.
joesmith123
L295DT, BX1500
Mar 18, 2023
527
134
earth
I understand
what was the point earlier when we saw that the rear pto is spinning but the rear tires won’t spin?
PaulL
2,433
1,363
NZ
I understand
I think demonstrating that something in the transmission was working - since the PTO drive is part of the transmission.
If the PTO is working then at least some of the transmission is working. If the engine doesn't sound loaded when in gear, then seems like the HST isn't even trying to drive.
Possible problems are (from NIW - just summarising):
- HST pedal not connected properly, so it's not telling the transmission to drive
- Range selector - if the range selector is in neutral then pushing the pedal will do nothing
No doubt there are other potential problems (more expensive ones) if the pedal is working but the HST not giving drive - it could be the HST pump or something. But better to start with inexpensive potential problems.
Another potential diagnosis is to lift the drive wheels off the ground, and press the HST pedal. See if the wheels turn at all. Also try turning the wheels by hand when in neutral on the range selector. That would eliminate seized wheels, and also tell us whether the HST is trying to drive at all (maybe with the wheels in the air they will turn a little). But from the video it doesn't seem like there's any drive at all - no change in engine speed, not even a little rocking - so it's like the range selector is still in neutral.
I noticed to start it you had to put the range selector into neutral (I think that was the cutout at the start where you shifted a lever before it would start). I think I saw you put it back into gear......but surely that would cut the engine? Perhaps that range selector isn't working properly?
joesmith123
L295DT, BX1500
Mar 18, 2023
527
134
earth
"engine does not sound loaded" yes, it seems like it stays in neutral
"HST pedal not connected properly" Soon I go get detailed video of that whole area but I did connect it properly
"Range selector" Its definitely moving the parts in the transmission
"Turning the wheels by hand" Yes, when it was lifted up, I can confirm that the wheels turned
Wheels dont turn when lifted up not even a little
"Perhaps the range selector is not working properly" I will get a detailed video soon and show you guys
