Bx Screened in enclosure
tinkerwitheverything
bx2370-1
Jun 3, 2015
319
72
Manitoba
It's a very wet year and the bugs mosquitoes are driving me nuts. I can't use bug spray so decided to build a screened in enclosure. I was able to screw the upper part of the screen to my sunshade using the exsisting screws that hold the tarp on. The bottom I used some cheapo velcro it's not holding to good as when it gets hot the adhesive is letting go .It works great except I'm going to have to buy some better quality velcro and see if it will stay stuck on.
rc51stierhoff
3,086
That’s a Great idea…I suspect you are not a fan of briars or multi flora rose😉. This is just a thought…I am not sure what is available on the individual consumer side, but maybe take a look at a product from 3M called Dual Lock…there are all kinds of different constructions and ways to fasten it and pending the type extremely durable. It’s used on wire harnesses and headliners in automotive as well as a range of other applications. It’s better/more durable than Velcro if you can find the correct product for your application. (I would be most worried about how it would stay attached the screen material). Keep us posted.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
173
196
Pennsylvania
I like that idea to keep bugs at bay, I use a boonies hat with netting, GI issue. Keeps the biting flies and, such from getting a meal off my face and head.
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
203
SW Washington
Boonie hat for the MFW! Former Aussie here……
FYI rc51 is spot on, there are some great 3M products that are like Velcro on steroids. Used quite often in the RV industry too. Most of my cab interior is held together by the stuff.
2,968
As long as you don’t have anything to pull the netting off…I LIKE IT!
