BX or b series
Highspeed
B-series
Jan 27, 2014
26
mid-Michigan
The B is a step up...literally! Consider your physical abilities too. I, like you, have deep snow that I'm moving right now (with FEL and blade), and it would probably be more difficult without the ground clearance of the B. Working in the dirt or woods it certainly helps to have the clearance.
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
I've got a B7610 that is 24 hp. I use a 60 inch 3 pt finish mower. It does everything I've asked of it. No issues, runs like a champ. I am considering moving up to either a L3200 or L3800. I need a little more weight for some tasks I have.
When I bought my B, I was looking at a BX series too and was talking with my dealer. He said that the B was a better choice. Bigger frame and such. More lifting capacity.
I like the BX's, but they seem like a glorified lawn tractor from 40 years ago. I know they are more than that, just how I see them. I love Kubota tractors. They were made to do the job, and get it done right.
Either way you go, I think you'll love it!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,257
2,960
Near Lancaster, PA, USA
kc8fbl, that is a parallel of my experience. When I was deciding on BX / B back in 2002 I felt as my Grandad would say "Like a frog on a mullen leaf" when on the BX. I knew they were serious machines, but it just felt too small. Went with a B7500 and ran it till 2012. The 21HP, weight and FEL were usually sufficient but frequently it would have been nice to have a little more capability. Sold the B and bought the L3200 in late May of 2012.
Can't imagine wanting anything different now. It is a beefy tractor without being too big. Much more comfortable to run than the B. It wears a 6' RFM instead of the 5-footers I'd been using for the previous 20-some years. Our 3+ acre lot has trees, creek and a couple sheds to mow around and it takes under 1/2 hour per acre to mow it. The L is more stable on side hills and doesn't need to be in 4WD in places the B needed it.
kc8fbl
Aug 23, 2012
222
Gobles, MI
my 7610 is 24 hp which seems to be plenty of power, but I want the lifting capabilities that the L series can do. I stopped by the local dealer and he was saying the L3800 is only about $1800 more than the L3200. Also said that the 6hp between mine and the L3200 wouldn't be too noticeable. I was quoted about $21k with loader for a L3800. I think that may be a little steep in price. I will keep looking around for now. :rolleyes:
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I have the BX with smallest HP (18) and that does the job nicely for mowing and most plowing of snow. However, you mentioned grading of drives, etc. . I assume with a rear blade. Remember the B and the BX are different. The B has a three point with lever that sets the location of the rear blade, up or down. while the BX is simpler, being mainly an on-off type valve. This controls the piston that pushes the arms up., sort of like how a hydraulic jack works. I find it much more difficult to do a good earth or gravel grading job with the BX than with a tractor fitted with what I call a standard three point lever control.
In deep snow, as driving over plowed up mounds, my BX does not do well due to ground clearance, but no lack for power..
Burt
Mar 24, 2012
337
Goldendale, WA USA
I Figure this comes up a lot but I am torn between a bx and a b series. I have about 3 acres to mow and a lot of it is around trees and on side hills some steep places. My gravel driveway is about 1/2 mile long and also a hill and right now it has about 18 inches of snow laying on it. Mainly the tractor is going to be used to mow but I want to be able to push snow, repair gravel driveway, do light bush hogging and every now and then dig/clean ditches. I want to be able to till some to plant food lots etc as well. I want to be stable and get good traction. I don't mind spending a little extra time to get a job done but also don't want to overtax the machine. I've looked at the bx25 that I like because of $ and it looks stable. I like the b3200 because of the extra power and lift capacity and weight but I think the larger size might be a problem when mowing around objects and such. And I sure don't wanna spend extra money for something that will cause me extra work when mowing which is what I'll do the most of. But I don't want to be stuck in deep snow when we happen to get 30 inches.
Flyfisherwes,
You've already had some savvy advice here on the OTT forum regarding your question. I'll add mine more as a ditto.
You can hire a lot of backhoe work for the price of the addition to a tractor. If it is not needed often, just hire it.
Put your money into BIGGER. Bigger will come back to get you if you buy small and wish later you went bigger. Country and rural life presents those issues unexpectedly.
Good luck and welcome to the Orange side,
Burt
