Unit is a BX2370.
I purchased a BXpanded underarmour for my BX. I install it last weekend. The problem is i can't get it to raise to the TOP position to lock it so i can use a 3point implement without it lowering. The instructions that came with the underarmour says to adjust the rod inside the left rear wheel turn in 1 turn and try it. That didnt work. I tried one more turn with the same result. The instructions say if 2 dont fix it there is another issue. I tried one more turn anyway with the same result. BTY i checked to see if its was hanging up on something and its not.
Where do i go from here?
