bx hill brake
ipz2222
L235, bx2670
May 30, 2009
1,927
31
38
chickamauga ga usa
Any one with a bx knows how the brakes are marginal. I have some steep hills that are wooded and I'm trying to clear some of the trees out. When I pull up the hill, set the brake and get off to load the fel bucket, the bx is slowly, and sometimes more thatn slowly moveing down the hill. These are spikes I made that quickly attach to the side of the quick disconnect. When I lower the 3ph, the weight pushes the spikes into the ground. It has held at the steepest hill with the fel full of logs.
2,845
You just might want to look into brake adjustment I have never had my BX drift on a hill and here in the coal country I got some pretty steep ones
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Looks great! I find on the L3200 that I have to push the brake pretty hard to latch it and have it hold, as well. But then, it does.
ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
May 10, 2013
143
Suffield, CT
That's a good idea!
