BX driveline question.
Whatscooking
Grand L 3130. BX2360. RTV900. GRASSHOPPER 721D
May 19, 2021
124
62
Indiana
For those that have taken the ends off and replaced and greased what do you find?
My 2360 with 850 hours has its boots dry rotted but no evidence of oil or grease flying out. I ordered everything I could come up with including the fan and the spring that returns the pedal to neutral.
As luck would have it the belly pan i ordered and they said would be 8 or 9 weeks, took 5, is all showing up Monday.
Everything is tight with the joints so i am thinking of making this a winter job. I want to hook up to the bush hog since i got the pan.
Ow I am getting the fan belt ordered while the driveline is out of the way.
2,412
Might get better responses if you explain what it is you want to takes the ends off of...
Obviously from the title something in the drive line...but...
Whatscooking
May 19, 2021
124
62
Indiana
Both ends of the driveshaft. By the fan and the other end where it connects to the engine. My boots are about gone so the driveline has to come apart. Different models can be taken apart in different ways to get the four balls out and lubed.
