ve9aa
Hey Y'all
Not much I can do about this at the moment, but with the quick hitch, ballast box, and various stuff in the box( weighed it all), I am at almost exactly 400lbS on the 3pt. (in the summers I ALSO have the 200lb MMM mounted.) I won't be filling my tires. My yard is mostly flat and only has trees on the perimeter 30' all around the 2 acres. We have little gardens here and there. etc. The usual "couple of acres in the country".
Previously I ( usually) had nothing back there except the quick hitch and found it very "tippy canoe" lifting more than 100lbs with the FEL or Pallet forks LOL
I know I could go more,(concrete, rocks, cast iron engine blocks, lead weights), but I won't be doing much in the way of "serious digging" or moving anything probably more than 300lbs around the yard, so the question is, given this, would only 400lbs ballast satisfy you if you were light duty, weekend warrior Mr. homeowner on 2acres (bx2380) ?
P.S. I am thinking of making a small "carry-all" attached to the back of the LP WB10 ballast box. (picture a very simple wooden "L" just to move things that may not fit in the bucket.
