Bx 25d
Pefea
BX25D
Apr 29, 2017
Langley BC Canada
I,m going to replace the coolent in my BX25D and can,t find the drain plug
For the block. The owners manual just indicates to drain the radiator but not sure if this does the block as well. Has any one changed coolent in a 25D. I see there is a Thread about a 2670 but not sure if it is the same.
Thanks peter
2,240
Thanks peter
It will drain the block as well (best possible) - how many hours on machine?
4,907
1,634
Once the radiator is drained, there is about an ounce of coolant left in the block. Hardly worth messing around with, IMO. If you're worried, use a blow gun in the top of the radiator to move some air through it (with the radiator drain loose) and you'll get your ounce out; but there will likely still be a few drops left attached to the pump impeller and the casting imperfections of the block.
