My Kubota BX 2360 wont shutoff. the solenoid seems to work when hotwired. the fuses all check ok. I think I got it figured out it may be the timer relay.
Where is the timer relay located?
Thanks, North Idaho Wolfman I found it.
I got a relay off of eBay. I put it on and tested it quickly just to see if it worked it seemed to work ok. I continued to put it back together; I started it up to run the FEL but when I went to shut it down it would not.
I checked the new timer relay, and it failed.
Any ideas as to what would cause this to fail so soon?
