BX 2360 won't shut off by main switch.
chief36chevy
BX2360
Oct 21, 2018
30
Annville
My Kubota BX 2360 wont shutoff. the solenoid seems to work when hotwired. the fuses all check ok. I think I got it figured out it may be the timer relay.
Where is the timer relay located?
Thanks, North Idaho Wolfman I found it.
I got a relay off of eBay. I put it on and tested it quickly just to see if it worked it seemed to work ok. I continued to put it back together; I started it up to run the FEL but when I went to shut it down it would not.
I checked the new timer relay, and it failed.
Any ideas as to what would cause this to fail so soon?
2,850
1,564
I think it's on the panel below the steering wheel and instrument panel.
5,531
First - - if you don't have one - get a workshop manual at www.kubotabooks.com
Second - - I looked at Kubota Tractor Corporation - Illustrated Parts List
Looks like part # T0070-31410
My seat switch acted up a couple years ago briefly. During that episode, my tractor wouldn't shut off from the key either.
Maybe reference the WSM before throwing parts at it. My Seat Switch was fine, just not closing completely.
