Bx-2360 mowing deck
gooney
mt. airy nc
I have a new BX 2360with a 60 in mowing deck and loader when I turn the knob to lock deck from going down it will stop at no.4 and will not go to the next setting that says top,it will go to zero the other way what is the problem it is all the way up when I do this????
1970cs
1,124
Grand Ledge
I think it's linkage adjustment problem! I have had this happen to a couple of times on some of the units I sold, but I did not stick my nose into the problem to check on what my shop did to cure this. I will try to corner them on Tuesday when everyone is back to work.
Pat
2,551
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Are you turning clockwise? Are you sure arms are all the way up?
I assume your index is on the metal cover of tank, etc. below your seat.
cerlawson
Feb 24, 2011
1,067
PORTAGE, WI
I just now looked at my adjustment and my deck sits as low as it can with the arms all the way down. That bolt and nut have no load on them there so maybe some up and down of things needed to make the job easier. adjust when no load is there and see what it does.
imnukensc
BX2380
Sep 10, 2015
688
591
Midlands of SC
Sounds like it's operating correctly according to what my dealer told me. That is what it is designed to do. For instance, if you're using a tiller on the 3 pt hitch, when you want the tiller to do down, you don't want the mower to go all the way down, but it will go down to 4 when you have it set to the top setting.
gooney
mt. airy nc
Thank you 85 Hokie you are a gentleman and a scholar that fixed my problem and to all who replied thank you also for being concerned. It is a bx2370dont know why I said 2360
