BX 2230 3 point lift issue
RacerX10
BX 2230
Apr 18, 2022
Russellville, AR
Have a BX 2230, when I parked it at the end of last season the 3 point hitch was working fine. Was getting it all ready to use this season and the 3 point hitch initially would only raise very slowly (and kind of stuttering / jerky), now it won't raise at all*. Hydraulic fluid is at the correct level. The speed control knob under the seat doesn't seem to make any difference, in any position from one end of the range to the other. Tractor RPM doesn't seem to have any effect either.
Where do I start ?
Thanks !
* UPDATE. If I work the steering back and forth, or at full left or right travel, the 3 point hitch starts working ??? (slowly). I was able to raise it up by messing with the steering end to end .. how in the world are they related ? Also, is 90 wt gear oil the correct fluid to fill @ the right front axle check point ?
Shekkie
LX2610, Virnig 60" Grapple, WoodMaxx TM-86H, Woods 60" BB/72”RB
Feb 12, 2022
183
306
Grafton, Ohio
If I am not mistaken you have one hydro pump that runs everything so that is why the steering manipulation caused changes in your 3 point……it’s all connected. As to why you are having the issues you are I’ll leave that to those smarter than me.
