BX 2200 trans leak
Wavewhacker
12
Henderson ,ky,usa
I have a bx 2200 that has a hyd. leak that repair has been attempted twice by the dealer. Still leaking ! Has anyone tried stop leak for trans. leaks ? Does it work, result, any possible problems from using it ? Thanks
2,965
Well I see you have not had a response. I was going to answer earlier but figured it would sound like a smart A$$ reply.
Can not help but think using stop leak in your system would change the tractor into a STOP RUN situation, as the HST was destroyed.
Just an opinion...nothing to back it up. But no way I would do that to my BX2200.
Wavewhacker
12
Henderson ,ky,usa
Thanks, it seems to be blowing back from the fan. I don’t like the “leak” stoppers either. Just miffed because I’ve paid for a repair twice and still have the problem !
5,207
1,893
there's a million places for the transmission to leak.
where is it leaking from? You said transmission but that doesn't tell us where the leak is propagating from. The source must be identified before it can be repaired
I have done these and I hate them. Full featured tractor that's only 1/4 the size of a normal tractor, so everything's PACKED tight, makes it really hard to find pesky leaks at the transmission
u have to use dye and a light. It is the only due to how the tractor (actually a big lawn mower) is built.
stop leak. If you cut your arm 3/4 off would you just put a band aid on it? It might slow the bleeding but it doesn't stop the root of the problem.
