there's a million places for the transmission to leak.
where is it leaking from? You said transmission but that doesn't tell us where the leak is propagating from. The source must be identified before it can be repaired
I have done these and I hate them. Full featured tractor that's only 1/4 the size of a normal tractor, so everything's PACKED tight, makes it really hard to find pesky leaks at the transmission
u have to use dye and a light. It is the only due to how the tractor (actually a big lawn mower) is built.
stop leak. If you cut your arm 3/4 off would you just put a band aid on it? It might slow the bleeding but it doesn't stop the root of the problem.
