bx 1870 FEL ballast
brimar
bx 1870 48" mmm fel
Oct 5, 2014
21
lancaster PA
I am a new bx 1870 owner MMM , FEL , Turf tires. The usage will probably be 80% mowing 20% loader work. Will filling the rear tires give sufficent ballet for light loader work ? And will the extra weight be to much weight for my lawn ?
84cj
Bx1800, 60 inch mower, front snowblower and bucket.
Aug 8, 2013
76
Gorham, Maine
My bx1800 tires are filled. Light work is no issue, and no problems with the lawn while mowing. Heavy work on slight inclines are not safe, a ballast is needed. After almost rolling two or three times, I made a 340 pound ballast for the 3pt. Noticeable difference.
5,307
Yes load the tires but also get a ballast box, or make your own! ;)
brimar
bx 1870 48" mmm fel
Oct 5, 2014
21
lancaster PA
Thanks guys for the input. Any idea how many gallons for each tire.and should I consider chains for snow removal?
2,219
you might be able to get 10 gallons per tire, that is gonna be over the magic 75-80% fill. Should be about 80 lbs per tire depending what you are using for the ballast. Chain - sure ! single ladder might not be the best grip - but are the cheapest to buy.
