Good afternoon everyone!
I will be buying a BX2380 very soon - with the following build:
54" MMM
LA344 Front Loader
R4 Tires
I will be using this mainly as my primary mower on almost 3 acres of mainly flat ground in Missouri. Also for driveway maintenance and snow removal of 2 driveways. Maybe transporting some fire wood as well
I can't get the 60" deck, won't be able to get around the wife's flower beds/yard decorations etc. So I went with the 54" and I don't need the drive over deck
I have a few questions if everyone doesn't mind.
I will be financing this through my dealer. Do I have to take the extended warranties he quoted me on the tractor and loader? I'd rather take that $1400 and buy another implement honestly. Maybe a rear blade? If I can take that $1400 and spend it on something else, what would you recommend? Quick hitch? Box scraper
Do I buy the Kubota bolt on cutting edge for the loader or is there an aftermarket edge that will be better?
Am I correct in assuming I want to add the 3rd function valve if I want to use the loader as a grapple to move sections of tree trunk? I don't actually know what the rear remote hydraulic valves are, would adding them now be beneficial in any way?
Finally lets talk about weights? I think I'd prefer to add weight as needed for snow removal etc and not fill the back tires. Is that correct? What would be my best bet to accomplish this? Wheel weights? Make a ballast box?
Thanks in advance and I hope I haven't been too annoying with all the questions
54" MMM
LA344 Front Loader
R4 Tires
