Im going to look at an early 90s L Series which the seller says has blowby and thinks it needs a ring job. Apparently it is bad enough that it doesn't like to start with just the starter motor so they drag it with a truck and bump start it to get going. He said it runs fine but smokes a bit. I realize that this could require a an overhaul or with some luck could be a relatively simple repair. Supposedly everything else works well it includes a front end loader.
I could get the tractor for about half of what a "good" one goes for. Im a mechanical engineer and pretty good with a wrench, so a bit of repair doesn't scare me, but im not sure how involved a complete overhaul on these motors is or if its even worthwhile. So I'm looking to get some feedback/ opinions from those of you who know a bit more about these machines.
Is it worth buying assuming it will need an overhaul, or is the effort and cost prohibitive?
Is there anything I should be looking at to help get an idea of what is causing the blowby?
If its been operated like this for a while could there be any other damage caused?
Thanks in advance.
Thanks in advance.
