Bush hog 50-06 rear blade on a MX4800?
trackman23
MX4800
Nov 22, 2023
65
10
NC
I have an opportunity to pickup a used Bush Hog 50-06 rear blade for a good price but it is listed as being designed for a 4WD max horsepower of 40 but I have 48. Is this implement a light-duty one that is likely to get bent up or am I likely to be OK?
Thanks
4,634
It all depends on what type of operator you are. If you think you have the weight and torque of a heavy machine and operate that way 100% of the time, you ought to pass. Otherwise you'd be fine, but I thought the "50' meant it was rated for 50 HP tractors.
trackman23
MX4800
Nov 22, 2023
65
10
NC
It may…Upon further investigation the 40 HP max was listed as the PTO HP…so very close to 50hp at the flywheel.
UpNorthMI
May 12, 2020
850
567
Up North, MI
Blade is Rated at 50hp at PTO you have 40hp at PTO, you will have no issue with the rear blade.
I’m not sure why Bush Hog use PTO hp as we all know a rear blade has no PTO connection!
