It has taken some getting used to. I am a bit large and riding this little guy can be comical. With each hour I am getting better. The power is very limiting. I watched the tree guys cut stack grapple flip toss and play with these trees like toddlers and lincoln logs. For the BX it was a struggle.
First Mud is not easy even with R4 tires. Nothing helps with such small tires. 4x4 is a must and when pushing hard and high I had to use the lock pedal continuously. For my size 13 in boots it is not an easy task. A bigger pedal is coming soon.
The lift is a sore spot as it cannot lift much. I find rocking the bucket and backing up then ramming forward helps lift. Keeping the logs rolling forward takes some finesse. In the end the huge pile was burnt o about 90% and only the mud stopped it before 100%.
I stand behind my choice of the smaller tractor as later I will not be able to get up into the bigger ones. After losing a hip I cannot climb a lot or very high. Even this little guy works me quickly.
I am thinking I may need some fire/flame guard for the bucket and is hoses. I also punched the lower plate pretty hard. I bought belly armor and a Piranha blade. I will have those on before the next wood burn.
Any one else using these little guys for wood piles? More suggestions for moving the burn better?
