Bucket cyliinder unequal length
HeartFixr
Kubota L3301, Land Pride BB1260 box blade, Land Pride QH15 Quick Hitch
Oct 5, 2024
Hickory NC
I have a L3301D-HST with LA534A front bucket. While using/abusing it, the bucket cylinders are not operating at equal length. One is extended or retracted more than the other. The bucket will move up and down but because the cylinders are not symmetrical in length, it makes attaching the implements very hard. Can I relieve the pressure on the cylinders and compress them to the same length without rebuilding the cylinder? How would I do that? What type hydraulic fittings does Kubota use?
7,159
The cylinders are supposed to be connected in parallel. That way they synchronize themselves. It sounds like your cylinders are not connected properly. Double check the hoses on the cylinders.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,797
2,360
WestTn/NoMs
You mention attaching implements, so I assume you have SSQA on your loader. There is/should be an angle or tube running side-to-side whose function is to keep the two brackets synchronized. It is common to twist this link, causing the two brackets to be out of plane. You should be able to twist it back by pushing against a tree, or by using one of several other methods.
7,159
That is some AAA+ mind reading :)
HeartFixr
Oct 5, 2024
Hickory NC
The cylinders were aligned properly until I abused them. Do I disconnect the hydraulic lines to the cylinders to realign them? Do I cap off the lines while doing that?
7,159
Did you read post #3? I think @PoTreeBoy identified your problem.
You probably bent the SSQA mounts. No need to disconnect any hoses. Just take the bucket off and push one mounting pad against a tree to bend it back into alignment. The tube bends easily so be careful - you dont want to overshoot and bend it too far.
