BT750 Backhoe (BT650, BT751)
sportscarclinic
B2150 w/LA350A and BT750 - B6000 w/S6000 - B7100 - B7200 w/B1630
Apr 11, 2017
25
Portland, OR
I purchased a BT750 recently that is missing the entire spool valve. I'm hoping that someone here has a similar backhoe, maybe a BT750 or 650. I'm looking for any information about the spool valve I need, especially pictures and dimensions.
What would be even better is an idea about where to find an aftermarket replacement.
Thanks,
Mike
Cloud
Kubota B20
Aug 5, 2014
22
Dalton Gardens, Idaho
Mike, I am looking for a solenoid for my BT 750. Were you able to find what you needed? Do you have any leads you could share on parts for a 650 or 750? Kubota doesn't supply them anymore. Thanks, Jack
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Illustrated parts layout for the various models here https://apps.kubotausa.com/illustrated-parts/
Not sure of the differences between models, but B21(BT751) doesn't have the electric solenoid/return to center swing feature.
I expect any valve off ebay or local supply would do as long as it has the correct flow requirements. The B21(BT751) has a couple of extra safety reliefs, (swing and dipper maybe, parts diagram will show) as well as main relief IIRC. The safety reliefs may not be available in the cheaper/universal valve blocks. Try surplus center or ebay and post up what you find.
Cloud
Kubota B20
Aug 5, 2014
22
Thanks,
Mike
Did you ever find your spool? I’m still looking for a green solenoid. If you have any leads I’d appreciate getting them. I haven’t been able to locate any used parts for my BT750. Thank you, Jack
