Hi all,
Had an issue during reinstall of the BT603 backhoe tonight resulting a mounting bolt from the base of the joystick to its controlling arm to break
The part appears to be a bolt with a ball end that goes into a socket of the control rod/cable and the other end which is screwed/embedded into the base of the joystick. (B1, B2, B4)
The break occured on the dipperstick/bucket lever (right if operating the backhoe) for the up/down function. (B5)
May be a unique issue...fixing might require buying more than just the bolt, perhaps it comes embedded in a new joystick? I am not sure if I can get the ball end out of the socket of the control rod/cable either. Trying my best to explain what these parts look and sound like to me, so correcting me on what these parts are is also desired! Would like to find out if there are part numbers here for me to give it a go before the last resort of going to the dealer.
Thanks all.
Thanks all.
