Broke pin BH-77
Jimmy3800
L3800
Mar 7, 2017
14
Rowland , NC
you'll have to determine which side is 'good' and secure that one to an immovable object THEN try the threaded rod trick.
if you don't secure the good side, tightening the rod may bend the good side towards the bad.
when I do this , I tighten a full turn, then pause for 10-15 seconds, repeat until it's parallel, then do it 2 more times, then go have lunch, 1/2 hr later, come back and undo the nuts on rod, measure. It may take 1-2 more turns to get parallel as the steel will 'bounce back' a bit.
Thanks I’ll try that
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
462
62
Red Springs, NC
So far I have been fortunate with mine however the earlier ones did have a recall my serial number was is after the recall I have not b able to find it, it was posted here several years back
