I've got a bx 2370-1 with 700 hrs and it has always used a bit of antifreeze. I have to add maybe a pint once every 6 mths. Took me awhile to find where my leaks. It seeps a bit from the weep hole on the water pump. It doesn't make any mess or anything like that on the motor or anything. I do know it comes from there because everynow and then I'll get a whiff of hot anitifreeze. The only way I found out where mine was leaking was that you can see the stain around the weep hole on the underside of the pump. I installed a cab and cab heater and put my return into the lower rad hose so when I was making up my fittings and hose connections I had to remove the lower rad hose and was able to really get a good look at the water pump. Its still under warrenty untill next spring and really for the amount of fliud loss that I have I'am not to concerned about it. Sometimes the mechanical seal on the pump shaft just doesn't seal quite right, be it on cars , trucks etc;
