brakes not working properly
crzybowhntr
m6040
May 27, 2014
Salem, WV
Hello all,
I have a m6040. When I step on the brakes in 2 wheel drive with the lever engaging both of the pedals, only the right rear will lock up. No visible leaks and the fluid is full. Tractor has 265 hours.
When I unhook the lever and work both pedals the left one will lock up but it seems to take more pedal travel than the right.
Thoughts?
1,411
There will be some adjustment (probably something like a turnbuckle) for each brake pedal.
Adjust the right side so it applies brake later and the left side so it applies brake earlier in the pedal travel. You can get them closer but probably never exact...
