Bob 62
Bob62
Kabota model L 175
Apr 19, 2015
Bay City, Texas
I have a Kubota model 175, very old model. The hydraulics work very slow after adding some fluid as it seemed very low. Can you add to much oil, or should it be drained and refilled
Thanks Bob
4,616
Theres a plug on the clutch side of the tranny. Should be orange. Thats the oil level indicator. Just fill oil till it starts to run out the hole. If your hydraulics are slow, i would check/clean the filter screen. Change the fluid if it hasn't been done recently. Could be a pin hole leak on the intake line to the hydraulic pump. Or it could be the hydraulic pump is getting weak.
